Why wont conical bolts work with ball seat wheels?
15K views 11 replies 8 participants last post by  corradog60stage4
Why? Apart from the obvious difference in seat why wont the coni bolts hold the wheel in place?
Actually, they WOULD work. But they wouldn't work RIGHT. Each arrangement is designed to have X amount of metal area with Y amount of clamping pressure distributed across it. When you change the bolt-type, you end up with a very small area of the bolt actually pressing against the seat. This results in 'Y x whatever' force on 'X / whatever' area.
This could be a very bad thing, under certain circumstances. Things could crack, or the bolt might work it's way loose.
#11 ·
I actually tried the stock ball seat bolts on aftermarket conical wheels and it actually wouldn't work. The bolt didn't seat deep enough into the wheel and all I could get was about one and a half turns on the threads (you should have three minimum) because the bolt just wasn't long enough. I'm pretty sure that if you got a longer ball bolt it would work, but why do it that way if you're buying new bolts anyway, buy the right ones. Right?
