Sensor clearance
Ok, So I forgot to get pix.
I can tell you the protrusion of the sensor from the inside diameter of the wheel bearing housing is 1.5-2mm. The clearance from the housing to the outer CV wheel is approx 4mm. This is on the side I did not attempt to pull the sensor. And again its a :b55:.
I did have some scrub marks on the sensor from the old axle's rotation.
I did not have an ABS light before so evidently the sensors are more robust than given credit for.
I also do not have a light after the test drive.:thumbup:
I turned the rack to opposite lock of the side I was working and there was plenty of room to support the spline end and get it out of the wheel bearing housing.
I would also say, You dont need an impact on the inner axle bolts. They are not in that tight and if you have the 12 pt internal socket head bolts, they will strip out with an impact. Air ratchet, yes. Impact, no. Take heart though if you strip one like I did, they come out with a vice grip on the Left side. Right side might need and EZ-out.
As for the total package, WOW!! Couldn't be happier, big improvement.
I wouldnt want it any stiffer for a daily driver, but the Koni FSD's do a great job of minimizing the shock.
The turn in and lane changes are tight like a tiger.
Next up, get the brakes to match the steering.
Big thanks to Koni, H&R, The Tire Rack and This Forum
Marc L.
