wide wheels on front of b5 help
2.2K views 2 replies 2 participants last post by  allnbst
Blades test fit (4) by nella1b, on Flickr
Blades test fit (1) by nella1b, on Flickr
Blades test fit (2) by nella1b, on Flickr
Blades test fit (3) by nella1b, on Flickr
As you can see I have a set of sawblades that are 9.5 wide all the way around. I bought 2 adapters at 25mm wide not knowing if i was going to use them on the front or rear. This is them on the front and how much clearance I have which is less than a finger. :cry: I obviously dont have my coilovers on yet but I need help deciding if I should order 20mm adapters for the front so I dont have as much poke or do I put those on the front and order 30mm adapters for the rear and have massive poke all the way around and not go as low as I would like. As for tires im looking at 205/45s all the way around. That should give me a good amount of stretch. Side note I have never seen another B5 run 9.5 sawblades on all 4 corners before. If I am wrong please point me in a directions of someone who has.:wrench:
