I disconnected (electrically) the N75 to log some "no boost" data. To my surprise I still got an easy 2 lbs boost, 3 lbs under really big load. Is this normal? What causes it?
I thought the wastegate was normally shut... airflow restriction via the throttle plate prevents uncontrolled spinup at low load, then [boost pressure --> N75 --> wastegate actuator --> wastegate] prevents uncontrolled spinup at higher engine loads.JDigga said:without the N75 the wastegate is held wide open.
It does it under all conditions (well, anything above 1400 or so). It's like it just naturally has 2 lbs boost.mghunt said:Perhaps, due to the exhaust backpressure, a portion still gets diverted to the turbine even with an open wastegate. Does it do this only from a stop, or does it do this when you are rolling and then stomp on it?
Not to mention, your increased intake flow has got to go somewhere.
-Mark
I'm not sure of the exact correlation of retard to knock sensor voltages, but typically cylinder 2 knock voltage is slightly higher than the others because of the position of the sensor, or at least that's what I always understood. You are reading off maps for 110 g/sec max MAF readings or something like that right? That could be the whole answer.Rusty said:No, actually cylinder 2 is easily my best cylinder. Those numbers come from cyls 1, 3, and 4 - they're all about the same, and all about twice as bad as cyl 2.
I never logged this data (2lbs and 7lbs, no Cartech, 380's) for the baro mod. But when I did log the baro mod (15 lbs + Cartech + 440's), the knock retard at WOT was unchanged.
I'm betting this is the answer - if the WG fails closed when you pull the hose, then you need some pressure to open it up. This will vary with RPM (should increase with RPM) since the flow through your exhaust causes higher back pressure at the WG as RPM increases, which requires higher boost pressure to open the WG.dutch-mountains said:When I had my N75J installed a week ago I blew some air through the middle connection (boost). It went out to the short outlet (WG). This would mean WG open IIRC when boost applied.
To open the WG you need some boost, this is the measured 2-4 lbs.
By "it", you mean the wastegate, not the N75, right? I don't believe pressure opens the N75. I believe the solenoid valve in the N75 has a "normal" position, and it only varies from that position when a voltage signal is applied by the ECU.Petra Passat said:if the WG fails closed when you pull the hose, then you need some pressure to open it up
Yes, I meant the wastegate not the N75 (unplug the wastegate from the N75, it stays closed, apply pressure to the wastegate and it opens)pete1 said:By "it", you mean the wastegate, not the N75, right? I don't believe pressure opens the N75.
Cool, thanks, that makes perfect sense.dutch-mountains said:When the N75 is unplugged available boost is applied to the WG, if there's no boost the WG is shut and stays there. When boost rise the WG opens. Measured boost is settled at a certain point were boost and WG-opening are balanced. It has become sort of a self-balancing system.
