So I've had a faulty one for a while. coolant temp on the cluster is pretty normal, but will dip from time to time, maybe once or twice in a workweek (15 mile roundtrip commute), and generally shows that the engine's at normal temp before I would think it actually should be. Commuted with vagcom this morning, and sure enough the needle set itself to 90 Celsius, but vag-com still showed it rising from the 70s to 90.
I have the new sensor (green) at my house, but can't get my fingers in position to remove the old one (v6), and since I've read that it doesn't effect engine performance at all, I haven't really felt overly pressed to get it done.
With that said - is this sensor's sole purpose to give the temp reading to the cluster?
