So running rough with misfire cylinder 1 code for the last week or so but it is intermittent seems more obvious when engine is warm and will get better if I turn off a/c. Possibly tied to engine load? Anyways replaced the coil pack and cleared the code with vagcom but it is back on the new pack. Decided to go check ICM and when testing with resistance mode from pin 3 on the input I get no continuity on any output pin!!! I know that I am testing the right pin but might I be missing anything? Also if the ICM was that dead the engine wouldnt run at all right?
TIA
TIA
