which sensor tells the transmission when to shift?
This page tells me something but not to sure if this applies to an 2001 passat glx v6 automatic trans
01m - TDIClub Forums
ALSO major thing here where is the correct sensor located on my car? Specifically the one that tells the transmission when to shift, possibly the g68? Could anyone provide a picture? i ordered the bentley manuals, but cannot wait for them to arrive to fix my issue. No codes from vag-com
G38 senses the speed of the sun gear shell inside the trans. It’s in the “middle” of the trans right next to the cooler. For a simple understanding of how it is used, just remember that the sun gear shell is stopped for 2nd and 4th and the speed with which it stops and starts, as the shifts, helps the computer determine apply rate of the clutches. In other words it uses this sensor to help control shift feel.
G68 senses the speed of the output of the trans. This is the one under the trans mount with a long harness on it. Obviously, with a transmission that is computer controlled, the computer needs to know what speed the car is going to make up shifting and down shifting decisions. It also compares this sensors signal with engine rpm to determine if the trans is making the correct gear ratio, or if the TCC is slipping.
G22 is on top of the differential section of the transmission and is used for instrument cluster signal, which is what I would normally call a vehicle speed sensor.
