Please if you are thinking of buying a passat or even a VW for that fact please insure before you drive inspect the lug nuts, and insure that if you have the lug nuts that use the special key that you have the key before driving off. I live nearly 2 hours from a dealer. and did not know that these cars had a key to unlock 1 lug on each rim. I've torn apart my car and after searching even on the forums noticed alot of people don't have this key either from the factory or possibly a used car and didn't come with it or someone had a tire changed and the tire shop kept the key. you do not want to be stuck on the side of the road let alone your SO and if you have kids. I finally got a key due to my brother stopping at a dealer and buying one for me then driving 2 hours to drop it off. I'm not trying to get anything stickied but I would say this should definitely be some information that needs to be posted more about. I've owned nearly 20 cars and have yet to see any other car with a factory special key. and trust me the only option that I had besides the key was to either disassemble the entire suspension with the rim and tire on. or use a welder and weld a socket inside the hole and use a wrench. (there are no other passats in my town I own possibly the only one I've seen yet so borrowing this was not an option)
regardless if you guys want to flame the new guy or whatever I'd rather get flamed and pass out helpful information, if one person goes to there newly purchased passat and notice this is missing it can save someone time and frustation
(note: the key should be in a little black pouche in the trunk that I holds your factory car jack)
