ECU, Exhaust, intake? Obviously not something like supercharger, thats not really in the realm with the rest of them.
I sense turbo envy.kawasakiguy37 said:brand? Theres tons of info on the stupid 1.8T chips, but not much on the v6.
Unfortunately the member "lipper" who recently sold his B5.5 for a G35 posted rather negative reviews on the neuspeed V6 chip . . . . therefore i'm hesitant about purchasing it.S_Klass said:Neuspeed chip for the V6. Neuspeed is a little mild for the 1.8T boys but perfect for the V6. Also CA Smog legal. Not everyone else can give you that assurance.
You'd be a fool to believe that those numbers mean anything. The UPsolute chip was already proven to not work.deezdubbin said:from what little info i have found, ive seen giac dyno 149whp where is my upsolute put down 153whp..... have not seen any dyno #'s on a neuspeed though so try and find something before you buy, numbers dont lie...
-deez
crew217 said:You'd be a fool to believe that those numbers mean anything. The UPsolute chip was already proven to not work.
The difference in numbers can be due to: different dynos (makes a HUGE difference), different atmospheric conditions, different engines (not every engine puts down an equal amt of HP), yadda yadda yadda . . .
The only way to properly dyno these chips is to use on stock car, all on the same day with preferably minimal time inbetween chip swaps in order to keep atmospheric conditions the same.
Dave
You're still getting it wrong . . . the upsolute was PROVEN to have decreased #s than stock . . . . hell an UPsolute rep even did the dyno himself.deezdubbin said:i know, but thats just way to much b.s. to see a possible 5whp difference. i do want to try that out but nobody around here has a v6 b5 that has a chip period...let alone a giac or wett. im kinda a loner here in buffalo ! my big thing was just the comparison of the 2 . apparently my upsolute isnt hurting too much if a giac ran less whp, right ? taking in to consideration all of the outside factors, i still dont think i would have compared that well if the upsolute was that bad !
-deez
you saying that 1.8t have no low end power...? :icon_eek:kawasakiguy37 said:No turbo envy, I like my reliability and low end power.
And I may one day supercharge my v6....I like having the power potential.
Here's the post:pacent said:
As a V6 owner I do agree with it to an extent . . . . however every V6 I've ridden in / driven that's chipped has had a noticable peppier spot in the middle of the RPM range. ~3k-3.5k there's a dead spot in the power band which is eliminated by the chip. I also do believe that they achieve a higher peak HP by leaning out the fuel mixture at the very top end thus producing higher numbers . . . however, whether or not the peak HP will do anything for you is highly arguable. As for "throttle response" its hard to judge since for most people IMO, its a placebo effect.Pacent said:Those who already have a chip, I really don't think your chip made a whole lotta difference as far as hp is concerned. Chip manufacturers can "improve throttle response" by making the gas pedal more sensitive to driver input...giving the illusion of more power. It is difficult to extract a lot of power out of NA cars using bolt ons, and even more difficult with just an ECU upgrade.
Dinan, for example, has been in the car modding business for 25 years now, a good 10 years longer than GIAC. Unlike GIAC, Wett, APR, and the other VW tuners, Dinan is also acknowledged and supported by BMW. The ECU software upgrade Dinan puts out for bmw's 3 liter and 2.5 liter engines yield absolutely zero hp gain. They admit to this on their website. They also admit they change the DBW programming on the car to give the illusion of more power. Go ahead and look it up on dinan's website: www.dinanbmw.com
I suspect these chips for our v6's do the same thing with very little or no horsepower increase. Does someone wanna prove me wrong by throwing their car on a dyno?
Ive never heard of improving the torque converter would result in a gain. I always thought the main reason to upgrade the torque converter is simply to SUPPORT mass amounts of torque, not that it'd increase your numbers.pancreas said:If I had a v6 i would do a GIAC /Neuspeed chip, Lightened pulley, BMC CDA, exhaust, lightened flywheel for a manual, level 10 torque converter for an automatic, ignition upgrade, port/polish the heads.
upsolute chip doesnt work on both V6 and 1.8T? or just not working on the v6crew217 said:You'd be a fool to believe that those numbers mean anything. The UPsolute chip was already proven to not work.
Dave
