I'm looking to buy a full FIS CAN based petrol cluster which fit a Passat B5.5.
What is the benefit / differences between this and a normal Passat instrument cluster? I don't see any oil pressure or ammeter gauges, but post a link to more info. on the cluster if you have it.
Does this cluster have an LCD/LED display that can survive ten summers of daily 150 degree F interior temps without the "
It's time to trade me in" display fade to black? If so, count me in.
edit: Looks possibly like the W8 (VCDS hybrid) cluster, where you can monitor lots of the same info. as if VCDS were integrated within the cluster (just a guess).
Well personally I can/have enabled the following with this cluster:
1. Distance to empty display (miles left based on the current fuel level/mpg)
2. Permanently illuminated needles, even when the lights are off
3. Cruise control light only illuminated when the speed is set (default is the light is illuminated when the cruise control switch is set to "on", not necessarily when the speed is set)
4. Welcome message enabled for the display
5. Idiot lights replaced with warning messages on the LCD, under the car status menu
6. Modern dial faces
7. Sat Nav directions (Direction arrows, road names and distances) displayed on the LCD - when paired with the VW MFD Sat Nav Radio which I also retrofitted.
8. Radio station/CD track display at the top of the LCD
9. A nice big LCD menu in the centre of the screen, rather than a half height one.
Also with regards to the LCD fading, the cluster I bought had a newly replaced LCD and so it should last a good many years before it "may" need replacing again. It's more likely the car will die before the LCD... and if not I can replace the LCD myself.
I will post some pics shortly of the cluster
