"whirring" noise coming from engine bay
25K views 44 replies 21 participants last post by  Tomvw
Since PW is working for the moment I will try any post. I posted this on B5one.com, but would like to get a few more opinions anyway.
For the past week or so, I have been hearing a faint sound thats like a low pitched "whir", almost like a small motor, or a slow blender, only softer. its most noticible after the car has warmed up and has been driven for a while.
I only hear it at idle, or at very light throttle, at which point it goes up in pitch, then comes back down if I let off the throttle. It sounds like it is coming from towards the rear of the engine bay on the drivers side. It does not seem to originate from the passenger side, or front of the car. However, it is not easy to pinpoint. It is sometime hard to tell with all the usual engine sound.
car is a 2004 1.8T, automatic, 60,000 miles.
I thought maybe it could be the water pump (which was fixed under warranty at 40k miles). No other odd signs, erratic idle, no fluid or coolant loss, etc. Car drives great , everything else is sound. Transmission shifts ok. The timing and alternator belts look ok. Im not sure how tight they should be, but they have about 1/8th inch of "give". Again, i could swear the sound is coming from the rear. It isnt very loud and isn't obviously originating from the front. I would just drop it off at the dealer while I get my brake light switch recall done, but I may not have time this week as I am working during the day and evening.
*Video below, the first one is the best of the two*
My worst (and admittedly paranoid) fear is that it is the water pump. Anyone know if that is what a bad water pump bearing sounds like?
On the V6 it sounded like a squeak, which didn't necessaraly have a conistant pattern. Happened twice.
It was quiet as you described so it was countered by engine noise, however I wouldn't call it a "whir." And it didn't sound like anything in that video
Also, listening with the hood open, it can be actually harder to hear than in the car, but if you hear it is pretty quick to be located as somewhere in teh front of the engine, though without a stethiscope type thing its hard to tell exactly hwere. However, it was not in the back
Yes, but lately it hasnt been as obvious to locate. It seemed pretty clearly toward the rear at first but the last few days it hasnt always (though it often has been) as loud when Im under the hood. All I know is, it isnt anywhere up top, and with the other engine noise, it is difficult to pinpoint.
If I had a mechanics stethoscope it would be easier to track. Unfortunately I have never seen one and imagine they are expensive.
#13 ·
yes, we do have them.
but unfortunately the use of this is highly limited as we're really only allowed to do work pertaining to our class, and Only when the course teacher is around to supervise.
i have an old 1950's oscilloscope if that'l help any! :lol:
more importantly, on my next trip to the tool store, i might just pick one of these up.
Xyro called me today about the infamous botomside clank and thought his tie rods were shot :lol: one would have deffinitely come in handy then!
turns out his tranny mount was shot, & knocked only when engine was torqued forward into drive because of the wheel torque resistance through the axles rocked the whole assembly.
#12 ·
For whatever it's worth, my car sounded very similar to that and it ended up being the power steering pump. Turns out someone used the wrong fluid in the pump before I got the car. Matter of fact I bought a brand new power steering pump today for $205.
#17 ·
If you want to swing by one day let me know and I can take a listen. I really can't pick out a whirring noise on that video.
A long screwdriver to the ear works well as a stethoscope.
#19 ·
When I was young I was completely fascinated by oscilloscopes. My dad would occasionally go into work on the weekends and would set one up and I would toy with it while he did whatever.
Anyway I went to Autozone (where people are always doing SOMETHING, today a guy was installing new shocks in the parking lot) and got the $10 stethoscope. I poked around the engine bay, there were several points where I thought I could hear traces of a noise at the same pitch level, however having not used one before Im not sure how much is normal engine noise. I THOUGHT I could hear traces of it at the intake manifold, head, water pump and oil cooler, but it seemed the loudest at the alternator, though without the stethoscope it seemed to be further back. I didnt have anyone to help blip the throttle to make the pitch rise and fall, which wouldve made it easier asit gets a bit louder at about 1000-1200 rpm then goes away..
Paul - I have monday afternoon free but thats it until next weekend, dont know what your schedule is like.
#20 ·
stethoscope
You don't really need to buy one of these, they can help find noise sources but it really helps to be familiar with the normal sounds in the area you are listening in. All you need is a couple of feet of clean tubing. Hold one end up to your ear and the other end where you want to listen to. The stethoscope to buy has both earpices and a metal tip on the other end though, right? Obviously use common sense, ie be careful around moving fans, pump pully, hot turbo.
#31 ·
I give up, it's going in to the shop on Monday. The worst part is I have to pay the ridiculous 50-60 bucks a day for a rental from Enterprise. Hopefully it wont take more than a day to diagnose and fix. Hopefully it isn't the alternator.
Good thing I got a good deal on my TB change. :lol:
#32 ·
My car was making a very similar noise. I raplaced the vac lines, pcv valve, along with tbelt and dv. The noise is gone, but I'm sure you've already done all of these things. Mine was more notiable sitting in the drivers seat as opposed to standing over the engine. One thing you could try is get stethoscope and try and isolate the sound, sounds crazy, but it works.
#33 · (Edited)
So the shop called me today. I'm looking at around $400 :(
Apparently, the sound was coming from the front, due to a bad bearing for a radiator fan that is inside a bracket, near the passenger side, and A/C compressor. The bearing isnt much but the job is mostly labor. It sounds like it could be pretty dangerous if the fan were to let go while driving. Not sure what exactly it would take out, but at that rate of speed it would almost take out something.
#34 ·
WOW! My car is SO incredibly quiet now. I cannot describe what a relief it is. Between the new bearing and the new tires I do not remember the last time my car made so little noise! Apparently this is not a common failure but the shop said they have been seeing more of them lately and just did another one recently.
The work order shows "Replace fan clutch bearing support", part number 058115136
