When i hit 80 miles per Hr my 1.8T rocks side to side??
1.7K views 15 replies 12 participants last post by  WhitePass
i kind of feel like its unbalanced when on the highway driving over 80 mph.
Its only feels like that when i hit over 80.
I grip the wheel tight and it still moves left or right by itself...really strange
when i got the same shimmy's, almost that unbalanced feeling. i found out my TRE's were shot.
check your Outer TRE's. check the boots, and if u can have it on a lift, check for any play. that was the culprit for me. and like you, above 80mph it would shake, but once i got it fixed, no more shimmy/play.
another culprit might be a wheel bearing..but i'm almost positive the play your describing is your outer TRE's. hope this helps :wrench:
#6 ·
If it's your TREs, your car won't hold an alignment. Is your steering alignment alright?
Also, you might have a smelly Isaeli sleeping in your belly pan and he starts running around when you hit 80mph. Or you have a bad trunk monkey.
#10 ·
I have the same issue but I KNOW my TRE's/suspension etc is all good as they are practically brand new, but I do have a VERY slight off center steering wheel so I'm sure an alignment would fix it. Just been lazy to do it.
#11 ·
i dont think an off center wheel can be fixed with balancing... maybe if it really is a small amount, but when i got my dash harness replaced, the d bags put the wheel back on at a queer angle.... kind of annoying....
