Solved: What's this rotation sound?
Hi All,
Just bought a 2002 Passat V6 (GLS 4motion, automatic and tiptronic transmission). This forum has already been extremely helpful to me, for replacing the PCV system for instance, so I thought I'd give it a try to see whether anyone can help me explain this weird sound I'm hearing. The sound is best described maybe as nagging, at the rate of wheel rotation. It seems to come from the passenger side, in the front (but that's maybe because it's relative to the driver's position). I have tried to record it:
https://youtu.be/Uxjzw2LfaWI
To be more specific:
- You will only hear it when driving forwards (not backwards);
- It is present when rolling forwards in neutral;
- Hitting the breaks will not make it go away;
- It is related to drive speed, and not engine speed (shifting gears won't change the sound's rate);
- The sound is likely not due to tire weariness as it remained after I replaced the tires.
Also, not sure whether the bearings are the culprit either. The wheels have little sidewards play. And the sound doesn't get worse/better when cornering or going uphill/downhill for instance. Moreover, it seems - I haven't driven the car that much yet - that the sound appears when the engine is warm. That is, usually won't hear it the first minutes after starting.
Best regards,
Arjen
Hi All,
Best regards,
Arjen
