what one do you guys use and how much. also how hard is it to install
i hanve the same problem with my 98 aeb NO CHIP (currently saving) with mbc im not an expert on the 1.8t motor but i was thinkin that the problem would be fixed with a pressuer reg. for more fuel or somethin does that make since ill be driven on the highway and if the temp drops and i try to pass a car ill get the bucks and i cant pass is this common with this motor and how would i get fuel to the engine faster.mghunt said:I have noticed that an MBC on my '98 AEB builds boost very quickly. Too quickly for the fuel system. I am not able to boost higher than 8psi without any bucking issues. If I have my aftermarket chip in, I have no issues with boost pressures higher than 1bar.
-Mark
wow, next time try using some punctuation.. that was hard to read.boosted1.8b5 said:i hanve the same problem with my 98 aeb NO CHIP (currently saving) with mbc im not an expert on the 1.8t motor but i was thinkin that the problem would be fixed with a pressuer reg. for more fuel or somethin does that make since ill be driven on the highway and if the temp drops and i try to pass a car ill get the bucks and i cant pass is this common with this motor and how would i get fuel to the engine faster.
jamil
