Im cleaning the bay, this is purely a cosmetic thing.
The vacuum reservoir i was referring to is the metal canister next to the power steering reservoir. Mad a hiss when i disconnected the lines. I essentially rid it of everything, There are two (or three) lines running off the crank case breathers from the oil filter housing. Ran one to the intake manifold with a check valve, the other to the valve cover which has a t fitting so i ran the other side to a dump next to the transmission to vent crank case pressure. PCV, SAI, EGR have been removed for a few months. Removed vac line after purge valve, left it open and plugged in. Removed lines from n249 and n112 (?) under the manifold, left those open and plugged in. Left factory vac line for WG, ran the DV straight to the manifold. I think that pretty much covers everything.
All i have left is the brake booster to the manifold, just waiting to go to the auto parts store later to pick up more vac line/heater hose.
Started it today and it idled fine, revved up without issue. Gotta run a vagcom to see if im getting any codes other than what i already had for downpipe and SAI. After all this checks out im gonna go into the fender and remove the charcoal canister and the hardlines that run to it. I also want to remove whatever the hell that thing is next to the power steering reservoir if i can. I'll post a pic
