you have to get the bolt out as the upper control arm's ball joint ends are scalloped to prevent them from "popping out" if the pinching fails. And the stub ends that go in the strut are rock hard. Two ways I have done this,in the car....taken a thin cutoff wheel and cut the bolt in the compression "slot" at the nut end then used the nut to "pull/extract" the little length out, then used a metric drill the size of bolt 10mm I think ? to drill it out using the length of open hole that I got the end piece out of, as a drill "bushing" to drill the rest out, alternating between drilling and inserting a drift punch and whacking, you will not have to drill all the way thru. The other way was I cut off all but about half the nuts height off of bolt, put nut back on and used remaining part of nut as drill bushing, drill size being the tap drill size for the bolt. . As a sidebar to this the bolt that is in there does not appear to be original clamp bolt.
