grnvdub said:
Okay so I installed the k04 on my 99 tip. Now I have a cel which is telling me that it's the coolant sensor. I also noticed after almost every drive 10min or 2 hrs the tb glows red hot. Is this normal. I can understand alot of heat on a long drive but on a 15 min ride home from work and it glows. Any suggestions on this? I'm afraid to drive the car in fear of screwing up the new tb.
OK, since you are a good turbo owner and have a boost gauge :thumbup: , and boost is normal - back to square one.
How do you know that your CEL means bad coolant sensor - did you have it read at Autozone or something? Assuming this is correct, then here's one possibility:
1) Your bad wastegate, resulting in little or no boost, has caused your fuel trims to lean out a LOT. It takes time for trims to readjust.
2) Bad coolant temp sensor could cause timing to advance if temps are reading too low.
3) Combination of advanced timing and lean fuel trims cause turbo to run hot.
But like I said - without a VAG-COM, we could really be chasing our tails...
Another thing you could do, if you have to drive the car until this gets figured out, is disconnect the N75 electrical connection. This will keep boost near zero...
If you are going to tinker with your car, a VAG-COM is a must-have.
And again - tb = timing belt or throttle body. Don't confuse us old guys any further, please.
