subframe piece
1 reading
1.5K views 16 replies 7 participants last post by  l5gcw0b
so on the bottom of our cars, there is one of these on either side of the car.
it has 3 holes, 2 of which are occupied by bolts.
these could also possibly be described as the "boobs" of the vehicle (get under there and you'l see what i mean.)
it's that part that has teh nub that comes down a bit which is often a common jacking point.
does anyone know what i'm talking about?
i was wondering if i could get this piece seperately as it seems to be a boltable part.
due to idiot owners, i'm missing part of them that was cut off, and to properly use this andy-bar, i would like to revert to the right ones.
#6 ·
Yes, I replaced mine and its only like 15.00. The frame bolt is really long and high tq. The other three (yes should be three) are like 30 NM. I would check Tq numbers and it might not be a bad idea to get new bolts while doing this too. Also Just do one side at a time for the subframe can shift if both are loose.
allright. thanks for the advice. i can see that easily slipping and moving a bit.
may be good to save this until i decide to purchase the upgraded rs4 mounts, as it helps to drop the frame slightly.
is the $15 a dealer price, or was that from somewhere else?
if there is a part number available, i would like to know it so i can order them cheaper.
