I was driving home from work as usual and the car seemed completely normal. But then I stopped at an intersection and the gear indicator turned solid red and the transmission seems to be stuck in 3rd. I pulled over and looked everything over no leaking dsg fluid or anything abnormal I turned it back on and the same thing happened, stuck in limp mode. I got it home and immediately tried pulling the battery terminals off and starting it and it is still in limp mode. There was never a check engine light or any other light on the whole time so I don’t understand why this is happening. Reverse works normal and doesn’t clunk into drive. 2002 Passat 1.8t fwd 5 speed dsg. It’s a base model gls so no sunroof to leak on the tcm.
Thanks! I hope someone can help me out
