squeaky wheel
Tags
squeaky wheel
6.6K views 18 replies 9 participants last post by  John prusinski
my front left wheel squeaks but it only does it at random times and it will only squeak if i turn left or right and sometimes if im going around 10 to 15 mph i dont really want to take my car to a shop untill i know what is going on i think it might be my bearing but im not sure any ideas?
Check the outer tie rod ends. If the boots are torn, water gets in there. Spray some grease and it may quiet down. You will need to replace the ends as the ball joint wears quickly once water and dirt get in there.
#10 ·
Spoke with a mechanic after getting my car fixed he stated it has to do with something about a CV / ball joint something like PZ said. He said it is not dangerous in turning, it becomes dangerous/needs fixing when it starts squeaking while you are going straight as well, not only turning. To fix it is like a $140 part. Gl.
