2004 Passat Wagon GL
Right side blinker will not come on. Indicator in cluster nor right side lights will not come on. Left side works just fine. Turning on the hazard lights all lights work, including the two indicators in the instrument cluster.
Have changed hazard switch, turn signal switch on the column, comfort control module and checked the fuse. (As far as I can tell there is only one fuse for turn signals.)
Have checked for loose wires on the hazard switch, column and CCM.
What else could I check?
And since this seems to be a popular answer to blinker problems, YES, I checked the blinker fluid too.
