Replacing Wastegate Actuator
12K views 16 replies 8 participants last post by  B5b4therest
#1 · (Edited)
Wastegate Flap Completely Gone! pics
Well, my wastegate actuator is shot so I am putting a used on in my a4 1.8t. I'll be taking the turbo out to do this because Ive heard its a lot easier than trying to work your fingers in those tight spots. My question is when i take the k03 out, how would I go about checking its health? How about gaskets, would i have to replace them when taking off turbo? Just wanna clear things up before I go about this.
Thanks
I will add that I have every indication that my turbo is not bad from viewing the intake side, (including minimal shaft play), but my car has recently become a smoker, and the cause is (most likely) failed turbo seals leaking oil on the exhaust side.
Yup, turbos generally go bad via coked or starved bearings on the exhaust side. Ususally, oil starts to drip into the exhaust downpipe, giving the evident oil smoke. They can also let go altogether, causing the full Naval wartime smokescreen behind your car. Watching following cars punch holes in the white clouds is kind of entertaing for a few seconds...
The turbine should spin easily, no binding, no scraping. If you can actually feel sideways movement, it exceeds .020" and will fail. A slight amount of lateral movement (in line with the shaft) is not fatal.
#6 ·
My 99' 1.8t Passat. Is also blowing smoke. Mostly when i use the tiptronic at high RPM's. Only reason i know is because a friend behind me told me. The previous owner said they had to replace the turbo because oil was dripping into the exhaust pipe. Is it possible that they didnt change the gaskets? Or is it something more. One more thing too, it was orignially running on normal oil. When they sold me the car they sold it with a bunch of Mobil 1 synthetic so i could do the change. Is it possible the change from regular oil to synthetic could do this?
Sorry, your original thread mentioned comments about checking to see if the Turbo itself is shot. I've done a bit of reading about the turbo removal procedure and it seems gasket replacement is always recommended. I don't think it would be worth doing all the work only to have to start over due to a leaking gasket.
I know it's not definitive, but based on my investigations - I'll be replacing gaskets.
#10 ·
Well, I took a look at the wastegate from this view below and the plug that closes the wastegate seems to be missing. There is absolutely nothing there that would keep the wastegate closed. I will post a pic later when I can barrow a camera. Does this mean a new turbo is needed? I dont think this is one of the things you can fix.
This pic is not mine
The squiggly lines indicat the plug that is missing in mine
Once again, Ill post a pic when I get a camera
#15 ·
Those K03's will probably work.
You will need to buy new gasket between exhaust manifold and turbo case, as well as the gasket between the cat and turbo. You will need a small paper gasket for the oil return underneath, and 2 copper o-ring crush washers for the oil and coolant lines.
Good luck.
#16 ·
If the parts for your waste gate were in the turbo and now are missing, you need to start looking for them in your exhaust system. I would think that such parts could destroy the catalytic converter, for instance. Also, something probably caused this failure; possibly extream heat in the exhaust manifold from excess fuel? Maybe the turbo was just put together incorrectly. Seems like a very strange failure. Good luck on rebuilding the waste gate.
