Power steering fluid question.
9.9K views 27 replies 10 participants last post by  2kpassat1.8t
Hello all,
I learned in this forum that it is not a good idea to use the brake fluid that has been opened and on the shelf for a long time. I have half a bottle of Pentosin power steering fluid, sitting there more than 6 months. Can I use it or the same brake fluid logic applies to PS fluid as well?
Best,
#2 ·
It matters more how many times the bottle was opened. If brake fluid has been sitting there tightly sealed for 6 months I would have no problem using it. But if it had been opened up a few times and portions poured out intermittently, I'd be hesitant. However, I don't think PS fluid is as hygroscopic as brake fluid is, so there should be no worries in using it. Is it the good Pentosin 11S type? Again, if it's only been opened up a couple times over the 6 months no problem using it.
I'm planning to use CHF11S The PS does not need topping up. I am planing to flush it. It has been almost 2 years since i replaced it. It is feeling a bit stiffer.
Although I will do a complete flush (draining the old fluid via the short hose using a bottle etc).
The CHF11S is a fully synthetic steering fluid, so you must do a complete flush. The power steering fluid the B5/B5.5 came with from factory is CHF7.1 which is a mineral base oil.
#11 ·
I suppose it wouldn't hurt, but you would need to watch the concentration with respect to the PS fluid. The transmission contains much more fluid than the power steering system.
Edit - Trans Tune is a product of SeaFoam, which seems to be a popular additive among many of the PassatWorld community. I'm generally skeptical of marvel mystery oil type products, but sometimes they do what they say. For example, I do use Techron fuel additive occasionally.
#17 ·
No matter what the cap says, the following sources seem to think that 11S is the correct fluid:
Pentosin - Hydraulic Fluid <----- I'd think Pentosin would know which cars their fluid is supposed to go in.
Volkswagen Passat B5 FWD 1.8T > Maintenance > Steering
Audi Power Steering Fluid G002000 - Audi Power Steering Fluid G004000
If you call the dealer and ask for the part number for B5 PS Fluid, they'll tell you it's G00 4000. If you check the Pentosin spec sheets avail. here: Pentosin - Hydraulic Fluid , you'll see that 4000 M2 is CHF-202. It's fully compatible with the previous fluid G00 2000, which x-refs to 11S.
FWIW, Blauparts refers to an old VW tech bulletin saying that 7.1 and 11S can be mixed.
#24 · (Edited)
As I, and vbora, said before, and as Pentosin, VW, ecstuning, and pretty much every single online parts dealer will tell you (even those few that still have 7.1 in stock), VW simply forgot to update whatever was printed on the cap. 11S was factory fill for the B5. Always has been. Call up your VW dealer and ask them and they'll give you the a number that x-refs to CHF 202. There won't be any warnings on the bottle, the Bentley, a service bulletin, or anywhere saying you need to flush out the factory fill prior topping off with the only VW steering fluid currently being sold.
And you'd think that Pentosin, who made both the old and the new fluid, would have some idea of the proper applications of their products. And they appear to be pretty consistent in saying that 11S was factory-fill for the B5.
I think the point of the note on the cap is that you are supposed to use hydraulic fluid instead of the ATF or generic P/S fluid that most non-Euro cars take. The note/cap was probably a carry-over from when 7.1 was the factory fill, and nobody ever got around to changing it.
#28 ·
As soon as I put CHF-202, my rack leaked at both ends. I shared my experience with a local VW/Audi specialist and they said not to use 202 in B5s, only CHF-11S. I wouldn't make a rule out of this, as it seems like many use 202 without problems. But ever since rebuilding the rack, I use the official VW fluid only, no leaks.
