Peanut butter in the heater core?!!
2.5K views 14 replies 9 participants last post by  axenstar
So I did the heater core flush today. Huge amount of stuff with the consistency of peanut butter and other corrosion particles came out. (In pics)
I had done complete radiator and heater core flush about 10k miles ago and filled it with Pentosin G12 and distilled water. I did everything by the book. Why still did this crud clogged the heater core?
The design of the heater core is not conducive to complete flushing. Most of the crud may come our, but some may stay. Try injecting compressed air at under 25PSIG to the water to act as a scrubber to get even more out. There are some posts around that talk about doing just that with a bought or home made device.
#9 · (Edited)
Opt for the more oily version next go around. Less likely to get stuck in the corners, and the excess oil keeps it a little looser.
Anyway, that's a hell of a lot of "peanut butter" to be in the heater core. I think you either:
A. Need to replace the heater core
B. Buy a blast vac: http://www.google.com/url?sa=t&rct=...NGRj6cRNguYxtDPV7IYOhNpQjk4kA&sig2=PtH3hdQPnHtpnrKad_apSQ&bvm=bv.54934254,d.dmg and try this method
C. Flush it the regular way until nothing comes out of it.
That's pretty nasty. Lesson learned either way: Folks, use G12 coolant! There is a reason why VW created a specific coolant for their vehicles.
#10 ·
Looks like someone mistook your coolant tank for a porta potty... Thought the chunky chocolate milk that came out of mine was bad.
Keep flushing a lot of water through it, looks like you're already using CLR too. Could try one of those prestone flush chemicals and water for a day or two, then make sure to flush all of that out. CLR is likely stronger though.
First time I did a coolant flush on my car the brown came back within a few months, the next time, I made sure the water was spotless and perfectly clear when I was done. I drained it into a white bucket to be sure. I think I must have done it at least 25 times over 3 days, and it's been nice and pink for almost 2 years now. Neighbors probably hated me getting the car to operating temp at midnight. lol Probably would have been easier and faster if the thermostat was more accessible on the V6...
#14 ·
When I flushed mine earlier in the year, I bought one of the drill pumps at Home Depot, filled the entire flush hose system with straight CLR, and the let the drill pump run for about 45 minutes the first time, drained everything and ran it again for 30 minutes the second time. This was in February of this year. Just to make sure everything worked right I flushed it again the last weekend in September, and I still got a small bit of crud out of it, nothing like you got though.
I think what you got was just leftovers from the first flush, much like mine.
#15 ·
What I did was I backflushed it. I read that it would dissolve more. So did it. I was surprised to see how all those stuff could be in the core. I used CLR but diluted it fearing that using it direclty would damage the tubes.
