New problems with my 2000 Passat
4K views 36 replies 8 participants last post by  pianoman2
About ready to take the Passat apart and sell pieces off of it to the highest bidder.
Latest problem now is after you drive it a while, it shuts down like you turned the ignition switch off, except of course all the dash and gauges are up and running.
Engine will crank fine, but won't try to start. After it sits and hour, it will start and run a while.
Anyone need any pieces or parts off this thing? Been a good car, but getting undependable now with nearly 200,000 miles on it.
Only trouble code stored is for random misfire on the spark plugs.
2000 Passat with 1.8l engine.
Any ideas, suggestions or matches offered?:banghead:
One other quick question... if the ECU was not getting power due to the relay not working, would the rpm gauge still show the engine speed while cranking? It's not much, but it does register the speed the engine is turning over. Wouldn't the RPM gauge be run off a signal through the ECU? If so, if the ECU is not getting power due to the relay failing, how would the rpm gauge still be working? Or is it powered another way? Thanks
Well, did it to me again. Fuel pump is running, the rpm gauge moves up a little while cranking.
Does the rpm gauge get its signal from the crank sensor, or from a cam sensor?
This thing acts like a gm product when the crank sensor is going out. Heats up, quits sending a signal, cools off it then will send signal again.
Crank sensor go out on these 1.8s?
Wouldn't you know it? Had time today to see if I could figure whether it's a fuel problem, or electrical problem. Drove the car most of the day so far and hasn't acted up once. In town and out of town about 60 miles so far. Have a trip this weekend, but not sure about trying to take the Passat. We'll see.
The other day it quit after 20 miles and waited an hour before it would restart. UGH! Gonna have to start drinking.
#11 ·
If indeed your only code is random misfires, then your car probably isn't missing a sensor signal, or ECU power. With 200K miles, change the fuel pump. They wear out, and sometimes you get lucky and get advance warning, like you have been getting. Sometimes you don't, like when mine just quit cold-turkey on the freeway, with a mile of no emergency lane due to construction going on. Fortunately I was doing 80 when the tach dropped to zero, and was just able to coast to safety, but it was a nail biter.
#12 ·
Against my better judgement, we had to make a trip in the car this weekend. Drove almost 400 miles round trip and the car ran fine. Always started, never acted up. Did not get a chance to put in a fuel pump. Go figure. Thanks for the suggestions on what to do and look for, but now have another car and will either sell this one or scrap it out.
#13 ·
Thought the new fuel pump had my problem solved, but the car would not start again today. Shut it off, came back out and it wouldn't start. Cranks fine, just no spark. Fuel pump is running and making good pressure, but when it won't start, it has no spark. While cranking the RPM will come up, then drop to nothing when you stop. So do I go ahead and loiok at replacing the crank sensor any way? Acts much like some GM products when the crank sensor gets hot and won't let the engine start.
#14 ·
That won't help if there is no crank sensor fault code. I'd check the power and ground at the coils, with a DMM, when it won't start. Pull one connector from a coil and probe the appropriate contacts with the meter set for Volts, looking for battery power, with the negative meter lead touching grounded metal. Also check the resistance between the ground pin and the grounded parts, such as the intake manifold, using the Ohms selection. If those are good, then you want to see a firing signal getting to each coil from the ECU.
#23 ·
Thanks, then that may be the relay under the hood by the ECU. If so I replaced it and still no fire to the coils while the engine is turning over. Guess I better start looking at the possibility of a blown fuse. Thanks again. Anyone else with ideas let me know. Ordered a manual on this car and should be in soon.
#26 ·
Well.... no power to F29 fuse whether or not the engine is cranking over. So for grins and giggles I supplied 12 volts to the fuse and the car starts and runs. Remove the 12 volt jumper and it will start a couple of times then won't until you supply the fuse with 12 volts via a jumper. Hopefully my book gets here so I can see how this fuse is supplied.
#27 · (Edited)
Check fuse 29 holder contacts, and Red/Grey wire to the "Motronic/ECU Power Supply Relay"
If the relay you replaced has 2 Red wires, a White/Black wire and a Red/Grey wire connected to it, that will be the "Motronic/ECU Power Supply Relay"
The fault is almost certainly a bad connection, in the relay or its socket, or the fuse or its socket, or the Red/Grey wire between the fuse socket and relay socket.
#28 ·
I'm beginning to believe it is the socket where the fuse goes. I noticed some corrosion on some of the fuses. You can wiggle the fuse box around a bit and it will finally make contact and start. So I'm gonna start there. I'll see if I can unbolt the box and turn it some so I can see behind it. Thanks for the suggestion on which fuse to look at.
