Ok, this is now driving me crazy. :banghead: My 99 1.8T 60K miles has been down for like 2 weeks and no one can figure it out:
Any other thoughts and ideas before I list my 99 1.8T in the Marketplace Forum?
-Mitch
99 Passat 1.8T
04 XC70 AWD
69 Triumph GT6+
- About 2 weeks ago, car wouldn't start, had to boost to start it.
- Checked charging system, indicated alternator needed replacement
- While hooking up another battery (instead of my regular), heard a pop and saw smoke come out of alternator, smelt like burnt electrical
- Sent alternator to shop, found all diodes blown and they replaced
- Re-installed alt and still found lower than 12V when vehicle running
- Replaced battery
- Removed alt and returned to shop. They bench tested and found 14.7V, 110A (mine is a 90A Valeo), and their test light goes out when voltage passes battery voltage. Brushes are good/clean.
- Checked both leads on alternator with ignition on and I have 12V on both the blue wire and the lead.
- Checked continuity from battery + to alternator lead and no resistance between them.
- Checked all fuses, they are ok. (Even the one's under the dash and that crazy one waaay to the left)
- Radio does not work as well. Don't even get a SAFE prompt.
- My connector under the drivers floor is like new.
- Battery symbol is lit up in dash. (Goes out when I remove the Blue wire from the alt).
- Brought car to an Auto Electrical Shop and after racking their brain for 4 days, they returned the car and said they didn't know and thought it was "The Dash". They didn't charge me anything.
-Mitch
99 Passat 1.8T
04 XC70 AWD
69 Triumph GT6+
