2001 VW Passat B5.5 1.8t, AWM Engine Type, Sedan
So today i replaced my SAIP and installed back my repaired ABS module. Also i poured Sea Foam into oil and gas to clean it up a bit. I did it all afternoon and after all this work car worked perfectly fine for around 40 miles. In the evening I was going back home from work and randomly he choked a bit and RPMS started going down, i noticed it and started stepping on gas deeper with no effect and eventually he just stopped and died. As soon as he died battery light came out. I tried to run the car with no effect, everything is turning around, spark is there and fuel is delivered (to injectors at least), but he just wouldnt run, the only thing is that battery light is on. Everything electrically is working, I called for my dad so we can give a shot to jumper cables (i knew it's not gonna work anyway) - no effect. Basically I "towed" it to my house (pulled by rope lol). And have no clue what to do. It's my only car and need it fixed asap. Also I'm short in money so if it's possible i just want to fix it myself. I was thinking that maybe the relay responsible for injectors doesnt open them up and the car doesnt deliver the fuel? Or maybe sea foam did something wrong? Idk, made oil too liquidy or something and the oil doesnt create any pressure? Oil light is not on though.... PLEASE HELP
