MBC: Greatest invention ever! (if you drive an AEB)
7.7K views 40 replies 14 participants last post by  bass_lover1
Another man's trash is another man's treasure...
Rochacha couldn't quite get his Dawes MBC to work in his car, so I bought it to see what the fuss was about ;).
Single best most, period.
The installation takes a little time, those hose clamps suck...but there is a trick to them. I replaced both of the WG and TN vacuum lines with the extra HTS line I had lying around.
After a few test runs, and realizing that I had it set on 3 PSI, I made a few adjustments.
The cool thing was, even at part throttle in low gear @ 3 PSI max felt MUCH smoother and stronger than stock.
After adjusting the MBC I'm now dialed in just around 9-11 PSI. Rusty was right though, the thing with the MBC, the gas pedal is like an on/off switch. Normal cruising isn't really affected, but once you mash the pedal, the car throws you into the seat and is off. It's not a bad thing, but it'll take some getting used to ;).
For all you non-chipped AEBs, do this, NOW! For the 40-50 dollars you'll spend on this, it's worth every cent. Also, once you do get chipped, you can use the MBC to limit spikes, so it won't go to waste.
#2 ·
Hmmm......I've been looking into one of these. I have a K04 and the onset of the turbo is a little bumpy. Once it's spooled in the 3k range it is smooth as can be but the 2.5-3k range isn't. Anyone think the MBC would smooth out the initiation of the turbo? It felt this way with just a chipped K03 but has been magnified a bit with the K04. Hmmm.........
99 AEB K04
Brullen exhaust
GIAC PC16
310 injectors
n75j
99 AEB K04
Brullen exhaust
GIAC PC16
310 injectors
n75j
I also have a '99 AEB K04 with a GIAC chip but not PC16 and 310 injectors. I see for the PC16 upgrade AWE recommends an FMIC. Did you also do this? I have the same "lag" between 2-3K rpm.
i have had one on my car since day 1. I will be upgrading to an electric boost controller. It is more surgy than normal. So your passangers get thrown around the car a bit to much. It is better than stock though.
#6 ·
MajinBuu^-^ said:
What is a MBC? what does it do? :confused:
Manual Boost Controller. In our cars the N75 valve controls boost levels by allowing the wastegate to open or close.
What the MBC allows you to do is take the N75 out of the equation, and puts you in control of boost levels.
It basically allows you to choose what kind of levels you want to achieve. On stock programming, it isn't wise to go higher than 10 PSI...I know that doesn't sound like much compared to stock, but since the AEB doesn't hit peak boost untill 3.5k or so RPMs, with the MBC I hit 11 around 2.8-3k RPMs...basically I'm at full boost, while you're still trying to spool up ;).
It does take a bit getting used to though, if you start to get into it off the line, watch out cause it'll put you in your seat.
Are you referring to peak boost (actual pressure) or peak torque?
Boost.
I have no way to measure torque (minus an email dyno), but I do have a boost gauge. I wouldn't tell you something that I'm not sure about.
#11 · (Edited)
I'm thinking about installing an MBC to hold me over untill i chip my '99 1.8t b5 this summer. I was wondering what the general opinion about puttting one on a car with only a 710n, and a boost guage. How much boost would be considered safe on stock software, ext. thanks
another question:
if i went with an MBC, air/fuel ration guage, 4 or 5 bar FPR, i should be able to hit higher boost than a chip could, or is the stock software going to restrict me?
#13 ·
another question:
For the 40-50 dollars you'd spend on it, it's a good hold over. My performance mods consist of an Evoms Intake, Magnaflow exhaust, 710N valve...I think thats it? On stock software, this is going by Rusty's reccomendations, I wouldn't go over 11lbs. Usually the stock fuel maps have a little headroom in them, and I wouldn't go much higher than that.
Honestly though, even though I only peak 3-4 PSI higher than I did before, the difference is night and day.
I'm on a stock K03 turbo, but the MBC allows almost instant spool up.
#16 ·
While it's not as fine tuned as a chip...you aren't changing any fuel maps to account for higher boost...it still only costs 40-50 bucks.
#20 ·
I don't have the FMIC but even in 5 degree weather it lags the same. I know I'm being picky, it isn't that big of a "lag" but it is noticeable. Maybe a high flow cat is next, I don’t know.
#21 ·
D.Passat00 said:
on the early AEBs, they use small injectors, compared to the later ones, and you're limited to 16.32ms.
I thought all AEBs had the 210cc injectors...it wasn't till the ATW motor did they start coming with the 252cc injectors?
#25 ·
very curious about this too. i have a 99 with about 113,000 miles. with cone filter diverter valve and i have a boost gauge installed to check the psi. is this a good idea to do it at this mileage? just lookin for something to make my baby quicker for the time being. lookin to get a k04 in the future. someone please educate me about this MBC deal. heard alot about it
#26 ·
you can read this thread here:
http://www.passatworld.com/forums/showthread.php?t=105475
but basically, install the mbc, and slowly raise the boost 1-2 psi, then log WOT 3rd gear runs, block 2, 20, 31. make sure timing pull (block 20) is in the low single digits, and block 31, front o2 sensor (1st set of #'s) are at least .875 from about 4000rpm to redline.
