If your turbo went, how much HP do you have left?
120hp? 100? The turbo adds in some kick, so I would guess it is a good amount of loss?
Its not that great a difference :2.0GTI said:keep in mind we have a low compression motor so you dont have the same power as a non turbo 1.8 20v.
Yea, now that you brought it up, from what I remember of the engine diagram, the air flow would be messed up because it would keep sending air to the turbo (which wouldnt use it if disabled/malfunctioned).PSM20VT said:I would say though that if your turbo has gone then you would lose more bhp due to the restriction that the broken turbo puts on the induction and exhaust gas flows.
Sorry what i was thinking about was more the obstruction that the 2 compressor wheels would cause if say the turbo compressor wheel shaft was seized, as the air being sucked in by the engine would be restricted by the compressor wheel and the exhaust gases trying to escape would be restricted unless you could open the wastegate to allow it to bypass the turbo.triptronic said:Yea, now that you brought it up, from what I remember of the engine diagram, the air flow would be messed up because it would keep sending air to the turbo (which wouldnt use it if disabled/malfunctioned).PSM20VT said:I would say though that if your turbo has gone then you would lose more bhp due to the restriction that the broken turbo puts on the induction and exhaust gas flows.
While on boost, the turbo engine consumes *much* more fuel than a normally aspirated (N/A) engine. Approx. 5psi absolute pressure for 1.8T N/A vs. approx. 22psi absolute pressure for 1.8T at full boost = about 4 times the fuel consumption in order to maintain the correct fuel:air ratio.triptronic said:Im assuming the turbo doesnt increase fuel consumption that much
Ouch, well, good thing you dyno'ed. I guess this can be part of the FAQ?Skuggah said:I had my '02 1.8T dyno'ed at DynoSpot Racing WHILE THE TURBO WAS DEAD.![]()
With Tip, and 17" BBS VZs, I wound up just shy of 100 HP and 100 lb-ft peak. So, that 115 HP figure seems right w/ drivetrain loss.
Really?! What does it do? The dealership replaced it under warranty, but they didn't say anything about possible engine damage. :nervous:Brags5 said:Skuggah, by running your engine w/ the turbo down, can't that cause engine damage? Least thats what i got from another thread.
The two people in that thread who said turbo failure would cause damage didn't provide any specifics.Brags5 said:Unsure myself, but here's the thread i was referring to: http://www.clubb5.com/forums/viewtopic.php?t=85906&highlight=turbo+engine+damage
Race cams with crappy low end? And nitrous?jaycevs said:I have seen modified mk2's with 20 valve heads and no turbo, making 300+ hp.
