How do I remove license plate bracket?
23K views 25 replies 17 participants last post by  ECS Tuning
The dealer put it on, now i want it off.
How do I remove the black bracket on the front?
I looked to see if there were screws but nothing.
I would rather the chrome shown than the front bracket.
Thanks for any help!
CHas
I had the same frustration after the dealer put them on (as they do as soon as they do their safety inspection with the car arriving from the port). My Salesman told me that they are snapped in with a "catch" at the back...sort of like the ceiling mounts you buy at the hardware store to hang plants.
He also said that it would leave holes the size of a nickel after you took them off.
I don't know how much of this info is accurate, considering it came from a dealer that I think ripped me off! (Leather vs. Leathette)
Hope this helps.
Jealius
Hollow Expanding Bolts
Hollow expanding bolts with center pins (or rivets since there are no screw threads) hold the frame to the front bumper.
VW factory instructions direct the dealer to remove the entire front center piece, so when the holes are drilled there is no danger of damaging electrical wiring routed behind the grill. The simplist approach would be to carefully tap the center pin in each expanding bolt, all the way through and out of the expanding shaft. This releases the expanded flare at the end of the shaft. Then carefully pry the outer edges of the head up using the flat of a putty knife or the VW trim tool. Once it has been backed out past the expanded flare, the bolt should easily come out. Use a small metal drift pin, or perhaps a nail with the point filed flat, to tap the center pin through.
Pulling the whole frame, hard, could damage the center grill $$$.
plastic rivet or a bolt?
Inspect the head of the plastic "bolt". Not to worry... VW uses expanding plastic bolts in all sorts of locations. They are on my '78 Audi Fox, '93 EuroVan in all sizes and shapes. If there appears to be a center "dimple" or a very fine circle that would be the center pin which spreads the flared legs of the shaft. If the head is smooth and one piece, it is not an expanding plastic rivet. Not sure? Try gently tapping the center with a small flat drift pin, if it moves you're OK. If it dents, it's solid.
#10 ·
Maybe you could find some Chrome plugs at the hardware store to fill the holes?
We're stuck with having the front plate as they are required here in Illinois. As crooked as Illinois is, I'm surprised they haven't eliminated front plates to save money and put the savings in the politicians pockets!
#12 ·
Removed Liscence Plate Bracket Yesterday
Did exactly what om3118 mentioned. Used a hex key/allen wrench and pushed on the smaller (inner) plastic ring. Had to use a hammer for the upper 2 bolts. They went all the way in and the bracket became loose. Then I just pulled out the bracket. (I hope the small part that I pushed in will have fallen somewhere on the road as I was driving, or even if its still behind the bumper somewhere, its not causing any trouble)
Now my bumper looks exactly like the what turbopower has shown. 4 holes, but still better than an ugly license plate holder that is not required in Indiana. (Although, sometimes I wish it was required by law, because sometimes I really want to call the police on the a-hole behind me, who is constantly tailgating/driving dangerously)
I have ordered europlates, and I'm hoping that they will cover these holes up, and not require any drilling. I might just get the 3M outdoor double sided industrial strength tape to stick it to my bumper instead.
#16 ·
Sorry, forgot to mention that I ordered both the plates AND the mounting frame, and was not sure if it will be of the same height as the standard American plate holder. I know the plate will be wider, but I am guessing it will be not as tall as the American plate - and in that case, the bottom 2 holes might just show..
Oh well, I am speculating too much. Let my plates come, and then I will see what happens and post a picture here.
#14 ·
Yeah, I have contemplated going this route, but I am not sure if I want to take the grill out and replace it myself. I am a serious car repair noob. I can do any and everything with a computer (hardware or software), but that's about it. I have no experience working on cars, and it looks kinda scary. I am afraid that I will f something up, and then have to pay a lot to get my mistakes repaired by some shop.
But, oh well... I guess every noob is like that. I might eventually end up learning stuff from doing it myself :)
#19 ·
Yeah.. But I think its better to have front plates.
Indiana is too damn cheap to provide front plates :)
If they try to, I am sure people will cause a commotion and blame government for robbing them (even more) of their money for something that doesn't matter (that's personal opinion)..
But that's a whole different can of worms.
#25 · (Edited)
I know this thread was old, just want to share my $1 hole cover.
I just moved to a province(In Canada) that don`t require front license plate. I took off the blanket by remove the grill (6 or 8 screw on top, and 2 in the bottom), then use pillar to get the rivet out from the back. Not easy, I feel like I going to break the grill.
Bought 4 smooth head screw in hardware store and glue it to cover the hole.
Not prefect looking, but for $1 only. I also ordered a small roll of chrome vinyl sheet from ebay. will try if that make a better result.
http://www.ebay.ca/itm/150755497182?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
