RechtsFahren said:
How 'bout Motul, Pentosin, or LubroMoly 5W-40? API SJ, VW 502 and 505, plus 500 too in the case of Motul. I've done a lot of hunting, and these three oils seem to combine everything we want: 1) synthetic with... 2) a wide range that doesn't include the hair-raising '0' number 3) a wide range that IIRC is the weight VW currently recommends for the 1.8T engine 4) SJ *and* at least two VW approvals. There is no Mobil 1 that combines all these elements, and IIRC Shell Rotella 5W-40 falls short on the VW approvals.
Oh nuts, SL is the latest...
There are actually two Motul 5w40 to choose from(Full & Synthetic Blend):
Motul 6100 Synergie SAE 5W40 100% SYNTHETIC
PERFORMANCE
Officially approved for API SL/CF - Energy Conserving*, ACEA A3/B3/B4
and CCMC G-4/PD-2 or G-5/PD-2 (*),
as well as for the following manufacturers' standards : VW * 502 00/505 00, Mercedes p. 229.3, BMW Long Life *, PORSCHE *, ROVER.
Volkswagen Gasoline and Diesel Engine Oil
TECHNOSYNTHESE® 6100 5W40 - VW 505 01
Specially designed for cars powered by Volkswagen Turbo Diesel 115HP engine (with pump injectors).
The SAE 5W40 viscosity grade is fully adapted to recent gasoline and diesel engines. The synthetic base provides high lubricating power resulting in
reduced friction and ensuring resistance to the increasingly high temperatures reached in modern engines.
The official recommendation of VW guarantees the quality of the product development and manufacturing process.
Anti-oxidation, anti-wear, anti-corrosion, anti-foaming properties.
APPROVALS : VW 505 01 / 500 00 / 505 00
Switched to Motul full synth from Valvo 5w40 since 30kmi...now at 40kmi.:thumbup::thumbup:
