Hazard Switch woes.....please help
2.2K views 12 replies 7 participants last post by  PZ
I was driving my wifes car(2003 GLX Wagon) on saturday, and after using the turn signal the relay kept ticking at random speeds. However, there were no lights inside or outside that would flash with it. This problem is intermittent but usually starts after using the turn signal. I replaced the hazard switch thinking that was the cause but the problem is still occurring. Im having a hard time understanding how it could be getting power to tick but without any lights flashing with it. Again, everything else is in working order still(hazards and signals).
Any help or direction would be great. And yes, I've (somewhat) searched:)
Thanks
Scott
I had the same problem. I did a wide search of the inter-webs and found that it is almost always the contacts inside the turn signal stalk. (PITA to replace the stalk).
I got a can of quick-drying electronic contact cleaner (Advance Auto Parts) with the spray "tube" and sprayed liberally inside where the stalk meets the steering column, moving it back and forth and left to right to make sure I was able to get the fluid inside and spread around the inside surface.
Let it dry for a little while, and it's now been perfect for two weeks and counting.
#11 ·
Did you try cleaning inside the stalk with the contact cleaner? It's an easy thing to try first before taking it all apart. - And it worked great for me! (And others who have posted in other forums).
The 'idea' is that over time dust/dirt gets inside and causes the contacts to lose proper connection. The cleaner removes that layer of dust/dirt and restores proper operation.
