front wheels and steering wheel shake when highway braking & it's not bad rotors/pads
1 reading
6.9K views 11 replies 5 participants last post by  gnosis
The front wheels shake, sometimes rather violently enough that it loudly rattles the steering wheel, while braking from about 55+ mph... doesn't matter if it's light braking or heavy braking. This has been going on for about two years.
I can't remember if it was shaking before I swapped the springs and shocks with Neuspeed Sports and Koni Yellows about 3 years ago, so I know that the suspension isn't at fault.
Less than a year ago I upgraded/replaced the OE pads and rotors with the A6 front rotors, standard OE rear rotors, and new pads all around. I'm still shaking just as badly. I also replaced the tie rod ends with the S4 TRE's. I didn't notice any difference in the brake-shaking with this mod either.
What gives? :confused:
BUT have you actually checked your brake system/components thoroughly- Our v6 2001.5 glx did that for awhile and it turns out that the inside rotor was warped on the front right. new brakes fixed that.
**BUT** again as what someone had said- there could be other factors- from worned CA, or TREs, or damaged wheel -etc.
good luck and let us know what conclusion you come to
e
your rotors must be warped. the new set you got warped also, and possibly wasnt bedded in properly.
i suggest getting front rotors turned(milled flat) and putting new pads on front, then following a strict bedding process.
I dont see how CAs would cause this only when braking. Then it would shake in other encounters also.
Had a free brake inspection at Midas. Front rotors are warped and the rear left rotor is pretty bad too. The Midas guy quoted me $630 to replace all pads and resurface all rotors. What a joke. That's about how much I spent to upgrade to A6-size crossdilled front rotors, new rear rotors, new Axxis/PBR pads all round, AND the labor.
I don't get any pulsed-braking or shimmy effect with just hand-braking so I'm not concerned with the rear brakes. I just want the front rotors planed and front pads replaced. I have an extra set of pads, so I think I just need to pay for the labor.
#10 ·
yup, i'll be replacing the front pads and turning the rotors this weekend, and I'll bed them in myself this time, thank you very much. The brakes I have on now were bedded in by the mechanic, so I don't know what he did exactly. I'm going by what the pad manufacturer (PBR) says: 40 mpg, light/medium brake to 10 mph, cool off for 1/4 mile, and do this at least ten times.
Also I forgot to mention that my front brakes have been constantly squeaky the whole time and I haven't been happy about that either.
#11 ·
Apparently cross-drilled or slotted rotors can't or shouldn't be resurfaced. Anyway I replaced just the front pads and it seems to have fixed the shaking steering wheel and uneven pulsed braking. Let's see how these new pads that I bedded in myself will hold up. They're definitely not squeaking like crazy... yet... as the old identical Deluxe Plus pads did from the start.
#12 ·
After about 300 miles with the new Deluxe Plus front pads, both the squeal and the warped-brakes feeling are back, steering wheel shake and all. I'm right back where I was less than a month ago when I started this thread. It's like I never changed anything! I'll be replacing the apparently warped A8 312mm Zimmermann cross-drilled front rotors with A8 ATE plain rotors. I should have them on in a week or two. This whole A8 upgrade experience has really pissed on my mod parade. And so much for "getting what you pay for." I paid the extra bucks for the sexy cross-drilled rotors and they squealed from the first week they were on 23,000 miles ago. My plain ATE rear rotors never squealed once.
