Ebay Vagcom? Who's tried them/has them? Do they work?
5.3K views 46 replies 21 participants last post by  branshew
Exactly as the title states, i need one to check fuel trim values and borrowed on generic one from a friend and can't get it to go beyond the initial connection. Was considering buying one of the ebay vagcoms that guarantee/ will refund even shipping if it doesn't work, so i might try one for the hell of it anyways.
Has anyone gotten an ebay/knockoff to work? Where did you get it from[ebay seller name/website]? Also did you need to download anything special for it, i've found a few things but everyone knows not everything on the internet works properly.
Thanks in advance,
Marcello
#2 ·
It really depends on the car. Newest VW's require the 701 version of VAGCOM software and the eBay cables only support the 501 version (VW's up to 2003 IIRC) Older VW's require the 2x2 cable. Also, if you are using an eBay cable, the software cannot be the shareware verison and expect everything to work. The VAGCOM shareware version/eBay cable will only allow you to clear codes.
Mine works great once the software was purchased. Get the computer drivers from the site and follow the installation instructions carefully. I do not remember the vendor.
#40 ·
Not necessarily unless you plan on VAGging later model cars w/ the HEX / CAN interfaces that require the Ross-Tech Cable.
On a B5 or B5.5 - you can do anything VAG COM related w/ an eBay USB cable. The full version will do more than the shareware (still w/ the eBay cable). for $99 software key from Ross-Tech and a $25 cable - I am able to do anything VAG related on my B5.5
I appreciate ross-Tech's efforts to make this accessible to everyone and I understand Ross-Tech's desire to make some money and I support that as well (by buying a software license), but subtract the $99 license fee and they are charging $150 for a USB cable that you can buy on eBay for $15. That cable should come w/ a tube of vasoline at that price. I would have bought a Ross-Tech KEY USB cable if it was $50 (dongle or not).
I just bought a OBDII code scanner from eBay for $40 (shipping included).
The business is in Shanghai (China) and it takes them forever to ship the item. They finally sent the item but the software CD was damaged. You gotta be careful not to buy from Chinese businesses. They mostly cheat or send fake items.
#12 ·
I got a vagcom reader off of ebay and It works okay. It will scan 3 sections for codes but it won't scan everything. I think it might be from the shareware. I'm really thinking that buying the software is the best bet. I'm not sure how the non ross-tech connector will work, but if I break down and buy it I'll let everyone know.
#14 ·
I had a bad experience purchasing a VAG COM on ebay! :thumbdown The guy sold me a vag com cable that my computer could communicate with. He eventually gave me my money back but I had to file a claim using Paypal. Since then I have been afraid of trying another seller on ebay. All in all, I guess it depends on the seller selling them to you on there! :thumbup:
#21 ·
Holly Shit! They are asking $249 for a simple cable. These guys are real crooks. No way in my life I pay $249 for a piece of wire. I'm gonna make my own cable. It's so easy. Just buy an OBDII cable for $5 and a USB cable for $3 and hook them together. Voila! There you have a genuine VAG-COM cable.
Be smart. Don't pour your money in pockets of crooks.
#19 ·
X2
Just bought the real thing at waterfest and have used it on three cars and logged some data, once you use it once you'll be hooked on the real thing, used it on three cars and found two bad coolant temp sensors, one bad O2 sensor and an N75 problem, those three alone cover the cost of the VAGCOM verses having a shop doing the work for you.
#22 ·
Doesnt work that easily or everyone would do it ross-tech software is made to work with ross tech cables, what you wanna do may work or it may not but all i know is that with mine i can log data and do way more then a genaric cable can plus i got it for less than that at waterfest. and its not as simple as hooking them together there's more involved with what wires to contect and if there connected right because if you put the wrong wire in the wrong spot than bye bye ECU and hello really big repair cost.
#28 ·
You can use the shareware but there are things that you cant use unless you buy the ross tech cable becuase of the way the cable is desinged it actually looks for the cable to have a specific code on it in order to run the full verison of the software otherwise you just have a laptop that can read codes and only look at data you logged and not save it
#33 ·
So much angst on this thread... look, Ross-Tech sells software and cables separately at various price points. Other people sell cables that (I gather) are variously compatible with various versions of that. If you want to get the best guaranteed functionality, buy from Ross. If you want to save money, try someone else. There's no right or wrong (except perhaps using hacked versions to avoid paying the price of the full-featured software).
#35 ·
x2.
I have the generic cable, but I only got it to scan and clear codes. If I want full functionality and be able to do more than a dealer can with their equipment, I'll pony up the $250
#36 ·
Because of the age of my B5 (99), my eBay cable and Registered Ross VAGCOM software is like an older home built computer, fully functional for me, but not up to the absolute current peak standards. This is a total investment of $125 well spent not having to travel back and forth to the AutoZone for codes or the dealership for TBA's when I leave the negative off overnight.
With 3 VW's, I can do everything that my cars need but cannot support others with significantly newer cars. I know the limitations of what I have, and they are acceptable to me.
#37 ·
I also use an Ebay cable (from alphabid as someone else mentioned) with a registered shareware version.
Works well enough for me.
#45 ·
I still think that the support that you get from ross-tech and the ability to do multiple things plus its a cable that you know will work and you have support if it does stop working, plus there really cool to talk to musta spent 30-45 min at there booth at waterfest talking with them about the cable and the various things that it could do compaired to the ebay cables
