Recently purchased a 2004 4motion GLX (V6 30-valve) with 66,000 miles. Since then, I have seen this advice about the timing belt:
Given the damage wrought when the belt breaks, one can imagine changing it every couple of weeks, just to be safe! Given the estimate I got for the work ($1,375, including the thermostat and water pump), one can imagine not wanting to do this needlessly - particularly just after shelling out a lot of money for the car.
I've searched these forums fairly extensively, but I apologize if I am creating clutter about an issue that has already been settled.
I'm going to have a 60,000-mile service on the car, and the belt will be checked. But I'd like to put the expensive replacement off until at least 75,000 if that's not imprudent.
Does anyone know what the definitive advice is for this maintenance? What should the mechanic be telling me to indicate that timing belt definitely needs to be replaced?
- The manual says replace at 105,000 miles
- My independent mechanic says VW has changed recommendation to the earlier of 75,000 miles or 7 years
- VW customer support told me in a chat that the recommendation has been changed to 80,000 miles for my vehicle and engine
- VW Chat person then immediately sent me a maintenance card last updated May 10, 2010, that still says 105,000 for my car
- I emailed VW customer support, and they promptly emailed me the maintenance card for 2007 Passats
- Various posters here recommend a lot of replacement times of 85,000 miles or less
- There is a sticker that appears on VWs and Audis that says "toothed" belts should be replaced every 75,000 miles, but I'm not clear where the stickers come from
