i had my shop do a test on the A/C. everything came back good, but the compressor clutch will not kick in. they said it has an electrical problem (LIKE EVERYTHING ELSE ON THIS CAR!!!
) so before i decide they start replacing everything else in the car i will try doing the relay, it sounds that it is a common problem so i tought i give a shot if easy enough. by the way my car is a 2002 passat sedan. and the fuse box is located on the side panel of the dash board to the left of the steering wheel. where would the relay be located then.
thanks....
