Climatronic Diagnostic Codes
20K views 3 replies 4 participants last post by  JohVW
It's probably something of a re-post (and cross post) - however our "robust" search feature did not return any hits for me - other than the recent "Hidden Features" thread. I went over to Vortex and found the info and thought I would post in here as well. Vortex post is here:
http://forums.vwvortex.com/zerothread?id=339642
This works only on Climatronic cars (GLX and W8).
Let me also throw in a disclaimer here - if you fiddle with the values, make sure you write down the defaults - I'm pretty sure turning off your car does not change it back!
*DISCLAIMER - this post is provided for information only. Any information used in this post is done at your own risk. Verify everything before proceeding or changing any values.
The "service mode" or whatever VW calls it is accessed by pushing the Fan down, Temp Colder and Econ buttons at the same time. To exit, press Econ.
Additionally, the display can be switched from metric (EU) and imperial (USA) by pressing the Auto and Econ buttons at the same time.
The codes are listed below (thanks to GMoney over on VWVortex):
1) System error
2) Value virtual temperature
3) Value inside temperature at the console
4) Value outside temperature water box
5) Value outside temperature bumper
6) Value blowout temperature feet space
7) Value blowout temperature dashboard
8) Display Check
9) actual value temperature flap
10) rated value temperature flap
11) actual value A/C flap
12) rated value A/C flap
13) actual value feet flap
14) rated value feet flap
15) actual value recirculating air flap
16) rated value recirculating air flap
17) driving speed
18) actual value fan voltage
19) rated value fan voltage
20) actual value on-board voltage
21) Amount of low voltage events
22) switch position high pressure switch
23) amount of volatile high pressure events
24) amount of non-volatile high pressure events
25) A/D Value kick-down
26) A/D Value heater light
27) rpms of the engine
28) rpms of the chiller
29) coding
30) software version
31) software index
32) error counter temperature flap
33) error counter A/C flap
34) error counter feet flap
35) error counter recirculating air flap
36) temperature flap cold
37) temperature flap warm
38) A/C-flap closed
39) A/C flap closed
40) feet flap endstop def
41) feet flap endstop feet
42) recirculating air flap endstop open
43) recirculating air flap endstop closed
44) counter driving cycle
#3 · (Edited)
Climatronic, default values?
Hi guys,
hope someone could help me out on this one..I, now officially a moron, did accidentally tamper with the settings on my Climatronic :whistle: What an idiot, I know..
So the Q is, what are the default values for these channels:
11. 0-255
12. 0-255
13. 0-255
14. 0-255
24. -99-126 (degrees Celcius)
The car is `99 Passat Variant V6 4Mo, sold in Germany. Are the defaults same in Europe and USA?
Thanks for your patient help :bowdown:
KimAnton said:
Hi guys,
11. 0-255
12. 0-255
13. 0-255
14. 0-255
BTW, climatronic selftest gave two codes: 313 00 and 318 00. What are those? Compressor doesn`t start and VAG-COM is pointing towards A/C pressure switch, so I`m getting the system refilled today.
Dit the same need also the defaults for the climatronic.
My Car is a Passat 2001 1.9TDI
Joh
