Beep beep beep ...stop ... Brake fault ... Service manual
1 reading
51K views 13 replies 11 participants last post by  Tomvw
OK, been getting this randomly over the past couple of days with the hand/park brake light on the cluster flashing.
Sometimes just turning right, others left too, also it sometimes stays up longer than others, seemingly only when it`s colder.
Done the VAGCOM thing and no codes are stored anywhere also had a brief look behind the front wheels to see if the ABS sensor wiring was binding but from what I could see, it`s not.
No other strangeness to report and the brakes seem to work fine.
Don`t suppose it`s something to do with the Fluid level...I`ve not checked that for a while.....
Anyone?
Thanks
Don`t think so as VAG-COM say it`s clean, in fact it says it`s all clean..... Maybe my VAG-Com is knackered!! :lol: :lol:
I think I`ll wait until it`s light and check the fluid level...... Don`t think I`ve ever topped up brake fluid on any of the cars I`ve owned, admittedly that`s only 3 (including my Passat) but hey... I did do a full fluid change on my old car though, along with some brake lines and new pads.
Does anyone know what fluid is in these from birth.... DOT4 or 5 or 6 or whatever, I doubt it`s eve been changed so that might be a job for the summer.
Any issues arise from topping up with the wrong spec fluid i.e mixing it?
Well it aint the front brake pads, they`re almost new but I have topped off the brake fluid and so far... so good.
Been a busy boy today and not finished yet so hopefully I`ll get chance to test it out on my next trip.
Anyway I got the Fluid from VW so it`s the proper stuff and they only had 1 litre cans of it so I`ve still got enough to do a full fluid change in the warmer months.
How long will this stuff last in the can? It`s tightly capped but oviously has been opened. Will I get a couple of months?
#12 ·
Stop...brake fault...servce manual
OK, been getting this randomly over the past couple of month with the hand/park brake light on the panel flashing.
Turning right,sometime driving straight, seemingly only when it`s colder.
First I check Fluid level, that was in level. Checked ABS sensor wiring, was good condition.
Done the Electronic diagnostic, no faults. The brakes seem to work fine.
Did anyone know whats wrong?
Thanks
