The vehicle is a 2003 Passat, V6, GLS, FWD, with manual climate control.
When I turn on the A/C, I hear a relay click the instant I turn on the A/C. But the compressor clutch does not engage the compressor.
Then, exactly 10 seconds after I turned on the A/C, the engine stutters just a slight bit, and at that same instant I can hear a relay click again. The engine stuttering after the 10 second delay is like a slight hesitation. It's like what happens when you clear a CEL code while the engine is running.
All clicking noises come from the area of the 384 relay, however, I'm not 100% positive it's the 384 relay clicking in all instances. When I was doing the above tests, I had a stethoscope probe touching the 384 relay. The initial click when I turned on the A/C was not as pronounced as the click after the 10 second delay. Also, if I turned off the A/C before the 10 second delay was up, I heard the same soft click as when I turned the A/C on. Maybe the softer clicks are coming from a different relay located close to the 384 relay? Also, if I turn on the A/C and wait 10 seconds until I hear the more pronounced click, and then shut off the A/C, I hear a double click. These clicks are very close together, so that it almost sounds like one. But its definitely a soft click and a more pronounced click occurring very close together.
I removed the 384 relay and opened it up to inspect carefully under a magnifying glass. Did not see anything unusual. So I put it back in, and the symptoms were the same as before.
I also checked to make sure the compressor was not seized. With the engine off, I was able to rotate the compressor with no problem.
Please let me know what you think. Thank you.
