Alright --- Stupid question that I definately should but don't know: What is the difference between the '99 and '99 1/2 Passat? I've seen this so many times but just never thought to ask.
I don't know all that many differences, but there definately are some small ones...IE - some of the relays are different, the coolant temp sensor is different...things like that. I don't know of any major components that don't match (ie - the ECU from a 98 will work on a late 99, suspension/steering components are the same, etc.)msummers10 said:Alright --- Stupid question that I definately should but don't know: What is the difference between the '99 and '99 1/2 Passat? I've seen this so many times but just never thought to ask.
There is...but it's very screwy. Mine was also 05/99, but it's an "early 99" model. When trying to source a fuel pump relay, my dealer couldn't match the one my car had to it's VIN...they had to use a VIN from a 98 model. Same deal with the coolant temp sensor.ganseg said:I don't think it relates to the '99 calendar year. His was built very late in the '99 model year. Mine was built in Sept '98. I would think there would be a VIN number cutoff.
I believe it changed MY 2000? Mine is an AEB & so is the 99 1/2 crowd.1.8tbeout said:is 99.5 when they stopped using the aeb engine?
I'm not a moron and do realize that there are 12 months in a year and half of that is 6. Like mentioned above, its not based upon the calander year. I don't know when volkswagen decided to change things and call it a 99.5. I just realize that its not based off the calander year. With your thinking, how do you explain the 2006 model year Passats being out already?PassatVariantPunk said:12 monts in a year. Half of 12 is 6.
I will not insult your intelligence completely.
Dates aside why do you need to know? Taking inventory of you relays?
Even those aren't always spec...my 05/99 has the full passenger mirror, clear turn signal repeaters, more hash marks on speedo, the late-99 sunroom panel/motor, yet doesn't have child seat tie-downs (which I would like to have...at least for another 6 months).selurffoeg said:early '99:
stubby passenger side mirror (vs full size)
amber turn signal repeaters on fender (vs clear)
less hash marks on speedo- every 10 MPH, IIRC
different sunroof panel/motor
no child seat tie-downs on rear hat shelf (i think)
those are the differences that i can recall...
That's where mine is...where is it on the late 99's?mrgreek2002 said:My car was built 7/98 and its an early '99, another way you can verify it, is by checking to see where the button for the gas refill door is located, if its located dirrectly under the middle handrest (on the right side of the driver seat) then its an early '99 for sure.
