Had my O/S rear door apart today to replace the lock mechanism (odd electrical things happening - suspect bad microswitches etc)
Anyway the part I had was the wrong one. Mine has a 6 pin electrical connector while the S/H one I bought has an 8 pin connector (I expect its from a B5.5). Of course I didn't discover this till I'd torn the whole door apart
So I put it all back together for now & will try again when I get the right part.
However, in the process of disconnecting the window glass from the lift mechanism I snapped a small tab off the white plastic piece on the lift mechanism that kind of secures it to the guide (I think!). The thing seems to be working OK but I think I should probably replace it - does anyone know if you can just buy that white plastic piece?
Secondly it was very wet inside my door which is (I think) because the door scraper (rubber blade) on the outside of the window (top edge of the door) is well past it's best. There is a big gap between the glass & the rubber (right over the lock mechanism!) & so water can go pouring in there.
I didn't really look too closely but do you need to take the door glass out to remove these & how are they secured to the doors? i.e. am I going to be drilling out rivets etc.? Having looked around the car I am going to need to replace all four of these I think so any tips on how to do this gratefully received.
