Howdy!!
I recently bought a 05 Passat TDI (BHW engine, trans is a GMR, 01V or 5HP19FL whatever you prefer lol) with trans issues, VCDS code 17117 / P0733 - 3rd gear wrong ratio. It is accompanied by limb mode and also the tiptronic will not do anything nor do the measuring blocks show anything for the tiptronic switches. I am not sure if the tiptronic absence is related to the main problem or a separate one.
When driving reverse and 1st to 3rd work and then it goes into limb mode / 4th gear.
Car's history is sort of unknown, previous owner got it with the same issues and occasionally tinkered with it - he replaced the trans fluid and filter and had the valve body rebuilt by a shop, to my knowledge one valve was re-done, the others were fine.
I tried another multifunction switch, tiptronic switch board and checked a few other things i found during many days of internet search. TCM is bode dry, no signs of previous water or corrosion anywhere including inside its metal housing. Wire harness looked good including those few wires that are merged and pressed/soldered together at certain points.
What I did find were suspicious resistance values for the trans speed sensors, solenoids were within their range.
Output speed sensor, pin 1 and 10 on transmission / pin 14 and 42 on TCM connector had 890 ohm
Trans speed sensor, pin 5 and 6 on transmission / pin 44 and 16 on TCM connector had 1870 ohm (and 1200 ohm when multimeter wires switched)
The resistances were the same on transmission connector and TCM connector, harness checked out good and all connectors are clean.
The only documentation i found for this task is a pdf from "Automatic transmission service group" and dated in the year 2000, before the B5.5. It lists the range for both sensors as 292 - 358 ohms.
Does anyone have the correct resistance values for this transmission or can confirm that they are the same as in 2000?
Would this be a likely cause for the failure/limb mode? If the RPM signals are wrong I could see that happen, but there were no codes for the sensors. (Does the sensor code get triggered when the signal is lost or if it is a little off??)
My next planned step is to drop the pan and take a look, however I do not expect to find much since the trans has less than 100 miles on it since the last owner had it refilled. But before doing that, i wanted to verify if the sensors are bad so i can replace them at the time i have the pan off anyway. From what i read they are inside the pan and one above the valve body. Is this correct and does anyone have the part numbers?
Any help is much appreciated!
Cheers :thumbup:
Cheers :thumbup:
