**PROBLEM SOLVED**
Duh. I had the tie rods installed upside down. Not possible on other cars I have worked on, due to a tapered shaft, but these have straight shafts and can be installed either way.
Something is going on in my front end and I can’t figure it out.
I recently installed new rear shocks, front struts, front control arms (all) and rod ends. All parts were Ocap from Blauparts. I did one side at a time and was very careful to compare the old with the new before installing. Everything went together fine, but when I took it in for an alignment, they told me something weird was going on. The toe angle was drastically changing, as the car’s weight was applied/removed.
I brought it home (slightly scary drive) and looked underneath while my wife turned the wheel from side to side. The only thing strange that I noticed was that the car would raise/lower quite a bit on each side as the wheels reached their limits.
I also observed how the toe angle changed. With the wheel straight and the tires off the ground, the tires looked straight. As I lowered the tires back onto the ground, both toed in quite a bit (~5 degrees).
I couldn't see anything else obvious.
I talked to a tech at Blauparts and he had not heard of this problem. I double-checked the old vs. new parts and everything looked right. I also made sure that I hadn’t put any of the left side parts on the right and that I got the sway bar links assembled in the correct orientation.
What have I screwed up? Any ideas are appreciated.
**PROBLEM SOLVED**
