Ditto: ONE remaining Upper Control Arm STUD (PIN) giving me GRIEF!!
Thank God I found a thread, date notwithstanding that underscores my FRUSTRATION:banghead:
towards the very end of a nearly completed suspension job.
Not having ever done a front suspension job before the last week and getting near the big 6 (like Jay Leno:lol
and doing it SOLO on a COMPLEX one such as we have, and my joints been INFLAMED for the last 6 days, I have been HUNG UP in the last two wee hrs of the morning dealing with getting the last of the 4 STUD (PIN that are the verticals of an H letter into the infamous pinch bolt IN
The pinch bolt is the cross section of that H!
The other three studs I got in (DESPERATION and PERSISTENCE)using a 5lb sledgehammer despite the fact that there is sooooooo little space to swing it in. And the spring action of the two upper control arms doesn't help as I'm a slight guy just 5'6" and 150 lbs.
I knew that a BIG C clamp would help but mine are only 2.5 inches (INSUFFICIENT). I've jury rigged this in so many permutations: used old rear bumpstops to wedge between the upper control arm and the "hat" to get the upper control arm DOWN and use a hydraulic jack to moderately squeeze it from the bottom; fooled around with the positioning of the steering wheel: ALL FOR GETTING THE PROPER ALIGNMENT into the Steering Knuckle. Spent an ungodly THREE HOURS playing around with these improvisations for this LAST Stud!! And probably 1.5 hr the previous wee hr day. The other three weren't easy but clearly nothing like this last one.
Everything else for the front suspension is done (3wks ago I installed the PureMS Front Tower Brace-tricky, challenging and really tight that I had to undo for this front suspension job). I did not have issues with the infamous Pinch Bolt thanks to Quality_Sound & NYCForever recommendation to use a centerpunch and big sledge hammer- no rust given temperate climate of SoCal. The Control Arm Studs (Pins) for me and the getting the fork of the shock into the lower control arm have been my PITA ( put one spring compressor into installed strut assembly and unknowingly got a box rachet wrench without a reversible switch STUCK when the springs were compressed from 5" down to 2": SCARED the living daylights out of me and PZ:thumbup:::bowdown: gave me some approaches to utilize and saved my ass.
I'm trying to avoid the Worst case alternative: bum a ride AGAIN from same friend to pickup a much larger C clamp!
So I need some experienced installers advice to cross the finish line here:
I've gone thru a lot of permutations in trying to align the last Stud of the Control Arm so I'm wondering is there a certain technique to finish this last one??? (It's the one with the Rubber Top of the Stud:Right Front.)
TIA:thumbup:
THE EXASPERATED ONE: So close yet seems sooooo FAR!
