Short version... twice...
First turbo recently sucked its waste gate into the turbine, jamming it. Car was drivable; but, barely. No power at all from idle.
Replaced it with a rebuilt (from a mechanic I trust) unit. That one broke the shaft in under 100 miles, and put about 2 quarts of oil into the exhaust sytem as a result. The smoke was unreal...
I just replaced that unit (tonight) with a new OE unit (that was stashed on a suppliers shelf for a number of years). The smoke was still fierce on start up; but, it has gotten better since I started driving it. Cleaned as much of the intake as I could during the installation process. I also drilled a small hole in each muffler assembly to let any liquid drain out.
Is there any otehr way to clean out the residual oil in the exhaust; or, do I simply need to drive the car to burn it off? Car runs great, other than the stigma of stinking up the roads!
Thanks
Thanks
