My 15,000 mile oil change is fast approaching. The question I have is do I have to take my B5.5 to a VW dealer for oil changes so as not to void my 50,000 48 month warranty?
Same theory here. Been taking my Passat to the same dealer for close to 7 years. The techs know me and my car [mods included] and been known to do some stuff for free since I use them for all maintenance. Always has a nice loaner car for me, even for oil changes.RobNick said:Nope. Anyone can do the work, just keep the receipts.
Around me, it's actually cheaper to have the dealer do it than go to a quick-lube place (which you couldn't pay me to go to anyway, but that's another story).
My $0.02? You spent a pretty penny on that car - take it to the dealer for your services, build a relationship with one of the service managers. It works out in the end with discounts, moving appointments up for you in tight times, etc. Plus, you'll know it's VW working on your car. Much easier to say "you guys have always serviced my car" if something goes wrong and it's their fault.
Rad, you won't void you warrenty changing your own oil, and I personally recomend it. However, if push comes to shove (and we've seen it here before), you'll want to be able to document that you did them when you were supposed to. this means keeping the recipts for the oil and filter you put in, and the date/milage the work was done. you'll need that whether you do it yourself, or if you let someone else do it.Rad said:I want to do my own too but I am trying to find out if that will void my 50,000 48 month warranty? If something happens down the road to my engine and VW comes back that they have no service record for oil chnages, you think they will will believe me when I tell them I did my own oil changes every 5,000 miles?
Does the oil extractor really get out all the oil? How do you change the filter without the oil dripping all over the belly pan and what not?jimbob said:Rad, you won't void you warrenty changing your own oil, and I personally recomend it. However, if push comes to shove (and we've seen it here before), you'll want to be able to document that you did them when you were supposed to. this means keeping the recipts for the oil and filter you put in, and the date/milage the work was done. you'll need that whether you do it yourself, or if you let someone else do it.Rad said:I want to do my own too but I am trying to find out if that will void my 50,000 48 month warranty? If something happens down the road to my engine and VW comes back that they have no service record for oil chnages, you think they will will believe me when I tell them I did my own oil changes every 5,000 miles?
I suggest looking into the oil extractor if you have a 1.8t, as the oil and filters are easy to change without removing the belly pan, which is a PITA.
I gave my dealer three strikes, once they didn't use the synthetic oil in the passenger seat I provided, twice they over-filled the engine oil. I can change my oil in about 10 minutes now.
I believe it gets enough of it out, I usually flush some clean oil through.Does the oil extractor really get out all the oil? How do you change the filter without the oil dripping all over the belly pan and what not?
Side note, I use Fairfield VW for mine. They charge $36, but I don't have a level place to do it myself. They say they are using 5w40 Castrol and sell it there as well. Can get an appt. withing 2-3 days at worst. They have done some warranty work for me and good about that as well. I live closer to Danbury, but it is at least 3 weeks for an appointment.Rad said:Thanks guys for your responses. From now on I'll be doing my own oil changes.
