I searched the forum and couldn't find an answer to this. installed an aftermarket stereo in my Passat B6 2009. The ground and ACC wires were exposed from a previous installation and ended up shorting. I have covered these wires now.
The problem I now have is that the stereo stays on after the key has been removed, previously it had turned on/off with the key. I have checked all the fuse (front/left/right) with a multimeter and there are no faulty ones. I tested the ACC wire on the harness end and it is receiving a constant power supply whether the key is in or out.
Any ideas on fixing this issue? Thanks in advance
