there are many threads that deal with this problem and I have read most of them. most point to a leak-down of fuel pressure in the rail due to leaky injectors or fuel pump check valve fault, or possibly a bad FPR. one member (rusty) found a bad evap purge valve, which raised my curiosity. so, my problem is like the others. the car won't start on the first attempt. how would a faulty purge valve cause starting issues? what happens when it is stuck open or closed? I can remember when the car would run like crap when I disconnected the purge valve. now when I disconnect, nothing happens. I thought the valve would buzz before...now I hear nothing...and NO codes!
