So last weekend I pick up a 2001 GLS 1.8L with about 129,500 K miles, the ad said the motor needed to be replaced because metal was in the oil. After some research I found out these cars have a oil sludge problem, so worst case the engine would have to be replaced. ( I can also pick one up from Pick-n-Pull for petty cheap)
When I picked the car the owner told that a local repair shop told her the motor had metal in the oil and that she needed a new motor. So after letting the car sit for over a year she sold it to me for under a grand and has given me the number to local shop. I called the shop the next day and asked shop owner what problems did the car have, he told me the car had oil low pressure and metal in the oil.
Today was the 1st day I had time to work on the car, the 1st thing I did was remove the valve cover. To my surprise it was petty clean, still had a light brown color tint to everything but no oil sludge, no evidence of metal particles. Next thing I did was drain the oil, once again petty clean however when the oil stop flowing out and started to drip out I could see little black specks in the oil. I removed the oil level sensor in the forward bottom of the oil pan and used an inspection mirror to look around, once again as far as I could tell everything was petty clean and I found no evidence of metal particles. I did find coked oil along the sides of the oil pan walls. Now I can't figure out where the local car shop came up with metal in the oil, as I can tell the oil panhas never been removed ever. :hmmm: I than removed a camshaft cap looking for metal scoring, but I found a speck of coked oil.
So I got in contact with the last owner and I asked her what happen to the car that made her bring it to a shop. She told me the "STOP" engine light came on and the car wouldn't go over 15 MPH, it just struggled to run and it shook. Now when I removed the valve cover I did notice the black rubber tube with 3 ports had a HUGH hole on the bottom side, it was so big my finger could fit inside, which = Vacuum/Boost leak. :thumbdown
Here is a pic of the hose I'm talking about with the hole (Red being the hole):
I checked for CEL codes with my scanner and I got P0011 Intake Camshaft Position Timing Over-Advanced. Looking at the Freeze Frame Data when the code pop, this is what I got.
Calc Engine Load(%)= 90.98%
ECT (coolant) = 197 degrees
Eng RPM = 5440
Veh Speed = 24 MPH
Short Term Fuel Trim = 3.13%
Long Term Fuel Trim = 0%
So from what I'm finding I thing the car has a major vacuum leak problem, and maybe a coil pack problem. I also need to see what this P0011 code is about, but I don't have a Passat FSM. Also is there a way to see if the coil packs had been replaced in the past (i.e. revised part number for the coil packs)
Eng RPM = 5440
Veh Speed = 24 MPH
