P0441 - Any possible link to...?
4.9K views 25 replies 11 participants last post by  Patrick Costigan
I have a recurring P0441 code...emission control system incorrect flow. This started happening shortly after I replaced the fuel filter. Is it possible that there is a leak somewhere in that hose that is causing the evap emission code? I don't smell gas or anything like that. I have had the purge valve replaced a couple of years ago, thought it unlikely that it's bad again. Also, the gasket on the gas cap seems OK, and I am always very careful to tighten it. Any thoughts?
#2 ·
What about your SAIP? Do you hear it work while on cold start? Could be a broken pipemor something related to the SAIP. Also, check your kombi valve, if your saip is not working and it is full of water, your kombi valve should be changed.
#15 ·
I have a 2003 GLX with the 2.8L V6 (ATQ). I think the part is the same for all the V6's. But you should be able to look it up by model year to confirm that on the website. Or, just call the dealer parts department, they can confirm the VW part number for your car and you can search the website by that part number. Good luck.
#21 ·
Is this Purge Valve hard to install? I have gone to several shops and replaced hoses of hoses and that P0441 still wouldnt go away. I just ordered mine from getcoolpart.com and hopefully it fixes it. Good thing I have similar car FriscoVW.
#24 · (Edited)
OK here's what I did and I have been P0441 free for 2,500 miles, (instead of the code coming up nearly every 300 miles). All i did was take the Purge Filter locatied on top of the air box, I disconnected the valve from the in and out lines, took pressurized air and shot it through for 20 seconds or so. put it back in and connected the lines. Also after every fill up I crank and torque the fuel cap to the best of my ability to get the tightest turn I can. Hope this helps because it did for me and its definately better than spending 80-100 dollars on a new purge valve.:driving: BTW I have a 2002 VW Passat 2.8 GLX non 4 motion 120,000 miles
